crash-harris
Breaker! Breaker!
Too much power? Probably not, but 2350 [email protected] is incredibly good if it's accurate. I'm using 2 JDM 10"- 1730 [email protected], each on its own relay, (1st relay controlled by thermostat, 2nd relay controlled by first relay) and a 12" 1730 [email protected] on a manual switch. I made a shroud that seals with neoprene around the perimeter and blow-through flaps that open at speed but seal shut sitting still so only cool air is ever pulled through the rad (3 row aluminum). Towing a car hauler and Chevy Malibu in the summer from Jacksonville to St. Petersburg, my temp never went over 205°F. I'm pretty satisfied with these inexpensive fans, they're holding up so far and they're cheap enough to painlessly replace should one (or more) buy the farm.
That's good to know. What material did you use for the blow through flaps? I really like that idea.
