CONTRARY to popular belief, the
INTAKE GRID HEATERS on the 1989-1998 Dodge/Cummins have absolutely nothing to do with starting the engine.
Their sole purpose is to lessen cold start emissions by warming the intake air.
There are four sitting in my yard at this moment that have all had those heaters dis-connected for many years and they will fire at the first touch of the starter on the coldest mornings.
Most all original Dodge/Cummins owners/drivers got their first diesel experience in an IDI Ford that actually required them to "WAIT TO START"; when they got the Dodges and they also had the "WAIT" indicator, they just assumed that they also had glow-plugs and not waiting would cause some sort of nuclear holocaust or somesuch.
The Dodge/Cummins grid-heaters are real power-suckers, with two 6-AWG cables feeding twin high-amperage solenoid-relays.
With only one Group-31 battery on a ZERO morning, those heaters can suck the life out of the battery and it then be TOO WEAK TO START.
E-Bay usually has several of the heaters and sometimes the solenoids listed by people that have removed them for the same reasons that I have dis-connected mine.
I have never known either the grid-heaters or the solenoids to fail, so they must be some quality stuff.
Again, just so there is no mis-guidance,
the intake heater in the Cummins has no bearing whatsoever on starting the engine, regardless of outside temperature.
That being said, in an IDI that actually does require glow-plugs to start, you may very well be on to something.
The best location for the grid would be in the intake-hat of a turboed engine, or directly inside the filter-housing of the original design NA engine.
The solenoid-relays would also be required.
This system would best be served by a separate isolated battery, such that the starting batteries would not suffer from the huge current draw.
My old 2-cylinder Mitsubishi tractor has a very similar intake heater system and will not easily fire on a hot summer day without it.
I would like to see the concept tried on an IDI; who knows, it may be a better replacement for the troublesome glow-plug system.
![Sweet ;Sweet ;Sweet](/styles/default/xenforo/smilies/Thumbup19.gif)
