Economical Way to Heat a 55 Gallon Drum of WMO/WVO?
mankypro
Learning Slowly...
Boulder County, Colorado
I'm looking at these band heaters for 55 gallon drums and even the ones with no thermostat cost at bast about $80.00 does anyone have a way to get 50 odd gallons of oil in a drum to about 150 degrees that costs less?
argve
Resident Fruitcake
Gwynneville, Indiana
I have been using a overly sized water heater element (220V) that I welded a bung on the side of the drum and screwed it in there.
jimmys f250
NIOBRARA, NEBRASKA
dont know if it gets hot enough,,but try tank heater for water tank, you just drop em in and the sink to bottom,,,get em at tsc or bomgaars
ksdrifter26
junction city kansas
i got a friend at work that makes bio diesel, and he uses a standard residential water heater, he just plumbs it directly into his 55 drum and runs a 110v motor with pump to curculate it.
Big Bear
