E4OD hard shift, trouble codes
lkrasner
Indiana
Finally got around to reading the codes off my '94 E350 Bus conversion. The transmission shifts rough and inconsistently through all gears (It will shift fine for a few shifts, then be real rough, not in any particular gear). The O/D light is flashing, though O/D does work. The button also seems to disable it, but is very picky (I have to press it a few times until it responds and enables or disables OD). I have already replaced the VSS, as that was what the previous owner was told the issue likely was by a shop. This seemed to help, but not eliminate the problem.
The Following codes came up under testing:
23 - TP/FIPL Sensor Out of Range
65 - E4OD truck – cycle OD cancel switch after engine ID is received – Transmissions
Any advice based on these?
lkrasner
Indiana
Ha! Went to adjust the FIPL sensor today, and found it was not even plugged in.. Plugged the connector back I and the transmission shifts like new. No blinking od light either.
SixFourShanks08
