Finally got around to reading the codes off my '94 E350 Bus conversion. The transmission shifts rough and inconsistently through all gears (It will shift fine for a few shifts, then be real rough, not in any particular gear). The O/D light is flashing, though O/D does work. The button also seems to disable it, but is very picky (I have to press it a few times until it responds and enables or disables OD). I have already replaced the VSS, as that was what the previous owner was told the issue likely was by a shop. This seemed to help, but not eliminate the problem.
The Following codes came up under testing:
23 - TP/FIPL Sensor Out of Range
65 - E4OD truck – cycle OD cancel switch after engine ID is received – Transmissions
Any advice based on these?
