e4od fluid path ?
homelessduck
I just ran my trans lines and want to make sure I have them hooked up correctly . The rear most line is fluid OUT , and the front line is fluid IN , correct ?
Sorry for the stupid question .. couldn't find it searching .
SLC97SR5
UT
Rear is return. That's how I remember it...
homelessduck
.... Are you serious ? I just spent all day in the rain and dirt running these lines .
homelessduck
Wow .. I don't even know what to say . The mess I was laying in was so bad I had to throw away my work clothes .. Now I get to crawl back in the filth tomorrow..
Thanks for the info :)
SLC97SR5
UT
That sucks, however what is the hard part? I haven't done the job, is it the little clips? Just picturing mine from memory it seems like a straight shot from the passenger side up to the rad where it tags the coolers.
Are you in a position to fill the transmission and crank it over with the lines disconnected just to verify fluid flow?
homelessduck
I thought it would be an easy , quick job .. but for some reason it took forever . All I had to do was bend new lines and hook it all up . I think my problem is that I was a little ocd about bending them . It was also pouring , I forgot the cooler was full of fluid so it puked all over me , and .. I'm just being a baby . I have less and less drive to work on it so even little things feel like a LOT . LOL
I'll swap them tomorrow . I'm sure you're right , no need to test. I still need to do some things to it before it can be spun over anyway .
justinray
Contributor
Cleveland, Tx
Why would it matter if it went through the cooler in one direction or the other, is there a check valve?
The rear line is the return and at the trans there is a check vlave. Its there to keep the torque converter from drining down when you stop the engine. Not a safe way to continue to start a truck either with a drained converter.
homelessduck
I'm going to run the front line to the cooler , through the filter , then back to the rear line . It's currently ran the opposite .
trackspeeder
Stone crusher.
North Branford. CT
You can run the filter before the cooler. Placement is optional.
As a rule of thumb.
New cooler old tranny, place the filter pre cooler.
New tranny old (flushed) cooler, place the filter post cooler.
truckonfire
