E4OD ATSG manual ordered...build soon?
raydav
Apple Valley, CA
Auction pic of book
Says REVISED EDITION
Hope its current!!!
It was revised when it was published, which was a long time ago. The two manuals serve different purposes. The basic manual will show you how to build it. The update manual is smaller and just covers how to take an earlier unit to 1997 level.
SDEconVan
San Diego CA USA Earth
ATSG, TransGo Tugger Kit, steel planetaries, updated sun shell, quality steels and frictions, new torringtons, re-bush, re-seal. I made a couple of tools, you'll need a decent dial gauge that can bolt to the alloy case for precise measurements. Also, to really do it right, expect to buy or have access to the snap rings (the ones that are about 10" in diameter, come in about 6 different thicknesses.)
Most of all, the encouragement and help from members here, it made my project happen! Still very thankful to Trackspeeder, FORDF250HDXLT, OLDBULLand others. Seriously, I owe Trackspeeder some beers, my trans build would have been a slap-together-special without his numerous inputs and advice. You will need a good, accurate digital caliper. You MUST TAKE A TON OF PHOTOS as you disassemble, lay parts out, and re-assemble.
Your first time in this trans will be sort of recognizable yet NOT exactly like other transmissions that you may have done. Expect to be PRECISE with this transmission, setting the end play specs, as you swap guts from one case to another, you will end up with different stack tolerances, know this and be prepared to adjust for it. Also you've got to be willing to stack sections up, then tear them down again, probably several times; if you did this for a living you could do it in one sitting, I've built 4L80E's, but they do not compare to a well built E4OD- do it right.
Be sure you have a very clean work space, I have a 1/4" steel welding table which I cleared/dedicated to just this rebuild (you can't afford to lose parts, believe me...)
Oh, along with building some tools, you must get an INCH-POUND torque wrench, it is worth the money. I could not believe the number of strip outs I had to deal with, 3 in the valve body, 3 in the front pump, and several in the fluid pan. Whoever the shop was that "built" my trans before had NO IDEA what they were doing, I am convinced of that, they even used CAR guts in a DIESEL trans!!!
Prepare mentally that you will have to do some heli-coils, if you get into a denial state, that will be the beginning of "The End" for your project. (Heli-coils are actually STRONGER than OEM, as there is much more purchase area by the larger, harder threads.)
Another thought, in addition to the ATSG, a factory manual would be great either online or in sections. You can find sections online, also the resource here, the awesome forum members turned out to be the BEST resources, I cannot emphasize that enough. To get that help it is important to get photos, photos, photos (I used my waterproof phone camera and good lighting, probably took 5 pics for every ONE I posted. Lots of editing and posting.)
Speaking of posting, here is my E4OD build thread, I ended up doing a "Stage 3" build (upgraded torque convertor, billet input, performance frictions and steels, steel planetaries, better seals, TransGo, and TONS of attention to the specs and tolerances.
What I ended up with is a transmission that I still cannot believe. I haven't even messed with my shift parameters, it feels so positive and strong and runs right in the perfect temp range. I've stepped on it pretty good and there's been no fuss so far!
Here's my build, which also includes the rebuild of my BW1356, with flanged output upgrades:
https://www.oilburners.net/threads/1998-e4od-on-the-outside-wait-a-minute.69057/
Have fun!
Best regards,
George
Got the manual...now hunting update handbook.
Then it is to sort out parts list.....
Either do full build or re n re 2wd to 4wd....
Right now just trying get the one in truck outta limp mode...
Well other than looking like a manual written by monkies and drawings so over copied and impossible to discern *** goes where.....it is clear...buy the parts needed as I see fit...take it to a transmission guy and say here ya go...pathetic excuse for a manual really...quite dissapointed in it.
Decided do some checks on my trans..bent neck in well...weird uncomfortable position...now I know how vietnam war hookers felt like.....necks cocked off sideways n all
So low amd behold I found what appears to be broken wires.
So based on these pics I am going to remove skid plate and then look into pulling down the harness to repair asap...like next week.
It honestly is quite long in tooth on n off clutch in traffic in Kelowna area where I am going to be working soon.
Hoping this ends limp mode as this truck worked awesome previous to the previous owners fubaring it. I knew the fella he bougjt it from and it ram drove well.
Thanks for looking.
Yeah I would say so.:D I told ya it was probably just something obvious didn't I?;)
Yaha....
Still not perfect..but at least D now has 1st..
Not plated so just backroad testing for now..
Tell me...are any 91 4xd E4OD harnesses the same...say gassers and diesels?
If so then pik n pul here I come cause honestly this is great to test and confirm but not long for this world...lol
Clearly it needs lots of work...so replacement would be ideal.
I want to get an entire harness for it...some wires still look flattened and such so may be cut inside....trans now has 123 but short test means no idea on 4th yet...
Yes pigtail will be had...an soon if pans out as ok
tke395
