Zigg, when does your tranny go in limp mode, when you have the lockup circuit open to prevent the solenoid from engaging? What does it do in limp mode, just maxing out the line pressure and making real stiff shifts? Ain't that actually better for city driving?
I'm thinking, if stiff shifts is the only effect of the limp mode, may as well go with that - limp mode and stiff shifts when no lockup, then with the manual there will be no limp mode as whenever the computer decides to lock the converter as tis already locked anyways. Actually, how often does the tranny computer check for limp mode conditions? I mean, once in limp mode, when you manually lock the converter and the computer decides to lock it up as well, if it sees the lockup signal will it go off limp mode? Or it will stay in limp mode until you manually disable it with a scan tool or whatever?
