E40 Tips and Longevity?
Black dawg
sw mt
You guys who are against flushing auto trans, what do you consider flushing?
Devon Harley
San Diego
Hooking up the meachine an doing a complete real flush. Drain an re fill with a new filter on an unknown trans is ok. Ipo I will not flush a used one only one with my personally maintance
Black dawg
sw mt
took my 94 turbo Kvin to get the solonoid on IP was sticking so got the IP remanufactured, when I got it back it had low power , jolt shifting and blinking Over Drive Button ....I checked all fuses in pannel and they are all good , any Ideas ? this is the second time I got it back from mechanic this way and the first time it was only a fuse, should I look for a different mechanic ? I wonder if they even dest drove it since you could tell it was shifting funny and the light was a blink ?
I would find a different shop, They apparently dont know much about your truck or even care to learn to do it correctly.
Devon Harley
San Diego
A code reader to re set the code an check the voltage sounds like there givin you a hard time.
Go into this post and edit it. In edit you can delete this post if it's not too late. Then start another thread, this type of question just confuses the original thread issue.
Thank You.
tke395
