E350 7.3 idi engine replacement
VanGo
Michigan
The new electric fuel pump is all hooked up and works properly I tied for it to come on from the hot side of the IP Via relay
The engine turns over, gets get gas. I have not attempted to start I want to make sure the glow plug controller is working correctly and make sure I under stand the return system: but very close, turns over strong alll new battery cables, ends, etc
So close
Can anyone describe the routing of the return lines in stock form?
Interested in how they would have been ran from the fuel housing, and how it came off the IP pump. Non turbo… I guessing one came from fuel housing to passenger side corner injector and the ip went to the drivers side injector-
I can't remember, but your guess sure sounds right to me.
Also since I am new to this how much fuel ends up going through the return lines? Droplets, constant flow. Just trying to get an idea on what to expect.
I haven't checked myself, but here's my guess. There should be a constant flow. Whatever the injectors and IP don't use will go back to the tank. The constant fuel flow also is used to cool the IP and injectors which is another reason to have flow. There should be volume, but not much pressure. In theory, especially when using an electric lift pump, the volume of flow should be less as the engine RPM rise. The engine is using more fuel so there will be less that goes back to the tank. It should NEVER be 0 returning fuel though. That would mean that there isn't enough supply to keep the IP and injectors cool.
gets get gas.
BOY I HOPE NOT!!!:eek: If it's getting gas, stop and drain your entire fuel system!;Poke
VanGo
Michigan
Today was a good day, bled the injection lines and the old girl started right up. Now to figure out how to update the heater hoses and put the radiator in. Then I can let it run a while. Also put in reverse and it also wanted to back up.
VanGo
Michigan
Before doing anything, since it sat a week just wanted to see if there were any issues firing up.no problem a couple cranks and it ran…
After the radiator install, tested for leaks. One minor issue at the top radiator hose.
Took for a short test ride to put in some fuel. It ran hot however that to turned out to be an easy fix. Just had to run it a bit longer with the radiator cap off to purge the air and the engine was running at normal temps.
I think we are good to put in the antifreeze.
For the engine work I think it is mainly tidying up the engine bay.
Then look things over as this vehicle has been sitting for years before acquiring.
Moving forward!
VanGo
Michigan
Have not had a lot of time to work on van, did add the antifreeze tied up wiring., started to take a look at the brakes. Going to drain and replace all the brake fluid, Freight d may take a look at the air conditioning, I would like to bolt condenser in and put the front end back together so it looks like a van once again,
Each time it has sat, for a week or longer it starts right up no problem, Once brakes are set I may give it a cleaning and put a plate on it to bring it to the house so I can start on the work I am excited about.
I was thinking I may look into to see what it would take to convert the rear end to disk brakes.
adnity
