I am not so sure I want to ask the question. I see it is easy to go down a rabbit hole on projects…
Swap engine, might as well do seals, probably gaskets it is old, yea a water pump is good. Should do head gaskets. If heads are off probably should get studs… etc.
From the beginning I wanted to go to electric lift pump. Initially facet then more reading. I will go with the universal Airdog R1SBU369
I see folks saying do away with the stock filter/separator what are the known issues on these?
Thanks
