Rain season is coming and I've got a cowl drain leak on the DS. Fender needs to come off so I
can check the seams sealing (or flowing, after our last short rain,) the water from going into the
DS footwell/kick area. It wets my carpet in the Left Kick area every time. The spot stinks of mold,
the metal below is getting rustier and rustier- a hole is coming soon.
Got a manual. You know how it says, "Remove the 3 upper bolts, then 3 inside the wheel well" blah blah...
they never tell you how hard it is going to be getting some of those suckers out!
...well, everything was easy-peasy, like to the point I was laughing how easy it was, until I got to literally
the LAST BOLT!
I've worked on a lot of stuff, and I don't see how I can access this bolt/nut combo. In fact, I don't see how
the factory could have put it in!!!
Ford must have welded the panels around this bolt AFTER it was tightened in place, then painted it and called it a day.
Passenger's Side (didn't want to walk into the street the local school was letting out and the Soccer Mom's
speed through the residential areas.) Note the fender is very easily accessible from all sides... ...except
at the Front/Bottom, just above the bumper.
Bolts never been removed before:
and like I said, easy-peasy. I was laughing aloud, I think.
Yep, I was laughing.
(Black bolt connects to Rad Supp.)
Closer, wait for it...
(View from underneath, looking forward)
Lowest/Front pinch bolt, wait for it...
There!
You can't see it because it is behind the spot juuust above the chrome bumper, that little
seam of white paint, outboard of the amber light. I can't get a decent pic of the last ONE bolt, because you'd
need a butt scope to slide in there to see it, and I loaned mine out. But trust me there is a nut/bolt
fastener pinching together the fender to the valence, a lot like the one below it, EXCEPT it has a double wall
construction and the fastener is INSIDE this space.
From what I can just barely see, it's impossible. I had to bend the fender away from the body to just
get a visual on it. No way a wrench can get on it, from either side.
So,
before I get a holesaw, plasma, cut-off wheel, does anyone know where the secret hatch is to get this
bolt? Or do I have to do something like remove the engine or flip the van over or something?
It's supposed to mist tonight so I should be okay but any advice on how to go after this pesky thing would
be appreciated!
Thanks in advance.
(Fire away.)
Best regards,
George
the LAST BOLT!
There!
So,
be appreciated!
Thanks in advance.
(Fire away.)
Best regards,
George
