So,,, 2 stock gauges????
But as above, go for it, ???? Post a tech thread for posterity.
Nice! Any pictures?Most aftermarket systems are 33-240 ohm; gauges and sensors are easy to find. Isspro I know has them.
I took the stock sensor apart and used the stock float and arm connected to a universal sensor bolted to the backing plate for the stock sensor. Somewhat of a bodged setup, but cheap and easy and it works decently. Hard part is putting it in the right spot so it reads right. My fwd tank is off some and reads ~1/4 when it's empty. Still better than nothing.
I'm hoping to find gauges that are the stock ohms... But, haven't had luck so far. I'm kinda OCD so all the gauges on my future custom cluster need to match. As of now, I'm planning on going with matched VDU gauges. Just need to work out how to do the senders.So,,, 2 stock gauges????
But why?
Two gas gauges seems like just a pain... just tie both tanks together to make one big tank, and run a single gauge off of it and return fuel to the front tank, if it’s tied together they will balance each other out
But why?
I like this idea, what are your thoughts on tying both tanks together?
Do you think just lowering the rear tank would be enough to get the fuel to move over correctly??It’s completly doable, there’s a few ways to skin a cat though,
1. Send all the return to the rear tank and add a line from the bottom of the rear tank to the front tank. The rear tank would need to be lowered so it’s at the same height at the front tank to avoid over filling. Then just keep it on front tank and it will supply fuel from both tanks
Or
2. Do everything the same as above but keep the returns in the factory position but instead of shimming the rear tank to lower it, just install an electric valve inline to the feed to the front tank from the rear tank, then just activate it to fill the front tank. You could even make your tank selector switch perform this function.
The rear tank is already higher than the front, it shouldn’t be an issue filling itDo you think just lowering the rear tank would be enough to get the fuel to move over correctly??
Sent from my VS980 4G using Tapatalk
