DT360 OR Cummins ID, IDI Value, Swap Info ??
Clydesdale
Nampa,Id
Or find the right c6 as they came behind cumstains in Ford 7k+'s in a factory application.
Clydesdale
Nampa,Id
I get loving a 401 (Blue Oval BABY!) or a 360, (Powered by IH!!) but before you discuont a ******** altogether, they are a decent motor.
Worstenemy453
King George, Va
How much would my complete driveline be worth.
If i sell it, it will have a new IP because im plowing with it as is this winter. She might hit 100,000 but i doubt it. Im getting a car for my job. Might be doing new IP and new injectors.
Worstenemy453
King George, Va
If you went with a Cummins you could keep your C6 Trans with the right adapter.
401 ?
I want a 360 = )
I know the cummins is a good motor but that doesnt mean i want one.LOL
BigRigTech
Diesel junky
Nova Scotia, Canada
Ford was using Cummins 5.9's before Dodge started using them - in there 5 ton class trucks. More than likely what you saw was a 5.9 or 8.3 cummins, did it have 6 valve covers or one? My 5.9 has a Ford part number and a Ford logo cast into the #1 valve cover.
Clydesdale
Nampa,Id
look for this...
Will say 6.6 or 7.8.
Then look for this...
Right in the middle of the valve cover..
Intake on pass side.. NON wastegated turbo on driverside...
From where you see my Kids hand, to the front of the pulleys will be 40" on a 6.6.. Little longer I believe on a 7.8
Yet to see a ******** with Alcoa so proudly emblazoined on the intake manifold
Ya can fit a *** Pump.. but it should have an MW pump...
Odds are if it's not a spittng image of this motor, its not a 6.6 or 7.8.. So that would make me think its a ******** if a 6. Could be a Kitty too, but one would think the ***** yaller would give that away from 100 yards.
Worstenemy453
King George, Va
The turbo was the Hx -40 on the passenger side, Bosch pump like the 360 pictured in the ebay ad. truck was a 1995 L8000 Box truck. I found an l8000 on craigslist with a 3208.
Worstenemy453
King George, Va
look for this...
Is that motor any good ? What motor is that ?
Clydesdale
Nampa,Id
Ferd 401/New Holland 6.6/Brazillian 6.6.
Has water in the 7l0, $400.
Replacing the IDI in my truck next spring maybe? should be an effortless 350-400/ 875-1000 for the output hp/tq #'s.
My "guru" says the 6.6 pretty consistently maintains a 1hp:2.5 ft lb ratio... sitting at 200/550 stock... HX 35 (or any in that stocker ******** familia) and some fuel tweaking/guv'nor tweaking.. IC.. should be able to get it right up there.
Worstenemy453
King George, Va
I want it.
crispy74
