aiyana7.3
IDI Enthusiast
Hey all, Thanks all the help you've given so far! I've got another question for ya though. I have been hearing a noise from under the truck - sometimes it sounds like its coming from the rear, and other times it sounds like its coming from right under the cab. The noise sounds like a clicking that usually happens around 25mph. Like two pebbles being clicked together. It comes and goes but recently has gotten a lot worse.
My friend and I put the back end of the truck up so we can turn the rear wheels. She started it and put it in gear while I listened for the noise. It does it in reverse also. While I was under the truck I put my automotive stethoscope on the transfer case, the transmission, the differential, near the bearings and couldn't pin point it anywhere. The only thing I could find is a slightly lose U joint that might be the problem but I was wondering if you guys have any other ideas on what it might be.
Also, the truck has had 4 inch lift for about a year but we recently replaced the old, broken and sagging leaf springs with some new 7 leaf leaf springs which brought the back of the truck up a little. While under the truck, I saw that my drive shaft was coming out of the transfer case quite a bit. turns out the transfer case was super low on fluid because the drive shaft is too short, but unfortunately filling up the transfer case did not fix the noise. I added a picture of my drive shaft --- is this too short? do I need to replace the whole drive shaft with a longer one or can I get a a longer yoke? Also, Ive read a little about the proper angle of the differential so there is less strain on the drive shaft. How do you adjust this angle and can this make my drive shaft work?
Sorry about all the long questions, I really do appreciate all the help.
