OB_WAN
I recently rebuilt my front calipers and bought new pads and rotors. I'm now experiencing some issues with the calipers dragging(when lifting the wheel, and turning it, I can feel the front pads grabbing the rotor allowing it to spin only 1/4 turn).
I noticed a few odd things during the rebuild/install. 1. the caliper pistons were corroded at the base and up the sidewall 1/4 way, pitted. 2. when installing the pads, I had to compress the pistons ALL THE WAY, some significant compression had to be done to fit the pads over the rotors.
I've got stinky brakes(dragging) and just removed one of the wheel hubs and noticed burnt bearing grease after 1month of running. wasn't there before. on a side note, I didn't have the appropriate hub nut socket so hadn't properly torqued the bearings so that could have been part of the prob(spinning bearings) but I'm guessing a lot of the burnt grease was caused by hot hubs due to the dragging rotors.
parts used for replacement were the best I could get from Napa/Reibees.
I'm guessing something is wrong with the calipers or pads causing the dragging but wanted to get your input. also guessing rebuilt calipers from the local autozone will be sufficient for replacement?
Thanks
Thanks
