discbrks
I have this idea, but I'm sure its not a new one. You always hear of someone wanting to route heater hoses to their wmo tank to help it flow in cold weather. And in the wvo world, the wvo is heated to 165+ degrees before entering the IP to help it burn. What about routing the wmo thru the trans cooler in the bottom of the radiator to heat it up before it goes to the filter & IP? Would it burn better? My guess is that it would be about 150ish degrees by the time it gets to the IP, which has got to be better than it being 80 degrees (or whatever the outside temp is).
Opinions?
Opinions?
