Sidewinded_idi
im trying to advance my ip and have all the bolts loose and it just barely wiggles back and forth. Do I need to loosen the injector and feed line to rotate it?
Thanks that would've been nice! And where did you use the pry bar at? I was using the 3/4 wrench boss up front but it rounded off before I could advance it any, my slots are right in the middle but I'm at a loss at this point. I barely got it advanced so that'll be all I can do for now
because there is not much meat on those squares, and everyone uses a Hispanic speed wrench. happens to me every time, is why I bought Jasons IP wrench.How did that round off? shouldnt happen if you've got the right size wrench on it square, I would see if you can get a big pipe wrench on it or some vice grips
I was playing with timing a lot a while ago when I first got the idi
never had to loosen the hard lines, this worked well for me
a turnbuckle, 2 S hooks, and a 3/4 wrench
one s hook to the closed end of wrench on ip and other to iirc fuel filter bracket using the turnbuckle in-between to set the position of IP. once set tighten the bolts on ip
that sucker is hard to turn, the turnbuckle makes life easy. IMO I don't see how someone could turn the ip, hold it in position and tighten bolts all at once by hand.. I'm sure someone has tough
