DIY glow plug harness
vandy7.3
wardsville, missouri
Anyone have any pointers for making your own glow plug harness? I need to move mine to a different location because it's in the way for running my intake, but the factory harness won't allow me to move it very far.
I plan on putting a manual push button in the truck and running all my own wires to each plug then the controller and to the push button.
All input is welcome!
Sent from my SAMSUNG-SGH-I537 using Tapatalk
drinkypoo
California
It's not rocket surgery. But consider going to eBay and buying a new harness from uhaul techcenter. They have one that will work with minor modifications, and which has really nice connectors on it.
Hmm, now that I've said that, I don't see them with any listed. That's sad. Here's one for $150, which is probably exact and requires no modification: http://www.ebay.com/itm/Glow-Plug-W..._Parts_Accessories&hash=item58abef7123&vxp=mt But that's a piece of money. Too big a piece.
As you can see, there is just not a whole lot to the story. It's got some bullets, some rings, and some spades.
Hmm, this is fascinating, this is all u-techcenter has for "ford glow" right now... http://www.ebay.com/itm/F0TZ9A451A-...ric_Vehicle_Parts&vxp=mtr&hash=item258a178985 ... is that a PSD part? Connectors look weird to me.
If your going to make your own harness, get some 14 Awg. fusible link wire and the 12/10 bullet butt connectors and 16/14 ring connectors. Azone and others have them. They also have the 1/2" plastic flex shield, and shrink tubing.
Remove the plastic on the butt and ring connectors and solder the wires in, then use shrink tubing to insulate them. Don't try to crimp them, doesn't make a good connection.
vandy7.3
I like the idea of a brand new harness, but I don't think they have enough wire in them to be able to relocate the gpc to a good spot out of the way of everything.
vandy7.3
That is about as far as I could stretch the factory harness and still have a decent look
vandy7.3
I'll have to pull the wire loom off all the wires and study it for a bit.
My main concern was the length of wire to get it all out of the way might affect the way the glow plugs work.
vandy7.3
Hey, early bird gets the worm iirc haha.
So if I build a harness I HAVE to use visible link wire? Or is normal wire fine? Cuz I got all the normal wire I would need already, but if I need the other stuff I'll get it
The little bit of length difference won't effect the controller. Each glow plug pulls 30+ amps, so if you make any wires longer be sure and use 14 Awg wire. I have a glow plug tester that proves that.
vandy7.3
Well sounds like a have myself a project after a quick trip by oriellys
It's just that fusible link wire protects each glow plug wire if the wire or plug shorts out. Just a safety measure.
Vincent
