I cannot loosen the nut that has the steel line attached from the lift pump without bending the pump and or stripping the nut. I am using a line wrench and still no go. Tried to tighten it a bit to free it up and still nothing. I used spray lube. My question is if I remove the pump with the steel line attached, can I use rubber fuel line in place of it. If so, what parts would I need to complete the connections? I replaced some gummy rubber fuel line.
Symptoms:
No fuel coming from schrader valve.
Tank is full.
When the truck starts to run bad and or die, I find that the fuel filter is half full. I refill filter and might get it to start for a while.
It is fuel related for sure.
Symptoms:
Tank is full.
