Diego Revisited
hacked89
Bucks County PA
Alas, sadly not worth getting oil all over my face LOL
I'll see what I can do about that at some point. I can tell you the basics though, and you can Google "ProVent 200" if you'd like to look into it.
Basically the gasses enter the filter at the side near the top, aimed at the side, so the gasses "spin" inside the housing, creating a vortex to separate the oil out. Then it has to pass through a stainless steel mesh (on the cheap knockoff ones) or a paper filter (on the original Mann-Hummel ones). Then it goes back out a hole on the side about 3/4 of the way down from the top. There is a drain nipple on the bottom for the oil to return to the crankcase (or in my setup, go to a drain tube).
I just plugged the drain tube for now, but I plan on adding a valve to the bottom of it to manually drain it.
So a catch can? We use those on most direct injection boosted gas motors. What benefit is it on the IDI? On direct injection the valves get dirty. Mercedes uses a centrifuge which is the best system on the gas motor side IMO.
Sent from my SM-G955U using Tapatalk
chillman88
Central NY
You'll have to let me know how it works out.
And yes, looking forward to news of how well it works.
Well... Uhh.... Hmm........
So I drove to work, then to Tractor Supply to pick up a new 7/16 bolt for the lawnmower. Got out to my truck and noticed a nice little puddle of oil under it. I know I bumped a return cap so I'm assuming that's all it is, and it's oily because there's plenty of oil left on the intake.........
Got home and popped the hood to see how bad that cap is really leaking and WOW. Oil was EVERYWHERE. I checked it and HOT it was almost THREE QUARTS LOW! Okay so let me back up just a little tiny bit.....
1. I don't check the oil as regularly as I should, shame on me. That said I've NEVER let it get THAT low, and I just topped it off a week or two ago.
2. When I installed it I noticed it was venting a little too much out of the cap.....
I don't know how well this is going to work. It was initially just venting to atmosphere under the hood. I noticed it has some kind of pressure relief valve that was super weak, and all the arms weren't pressing against the spring. I stuffed a piece of hose in there to stiffen everything up, and pressed it in far enough that it doesn't open just by looking at it anymore.
3. I had taken the line to the filter off when I installed it and thought "wow it's really working, I'm not seeing anything coming out of here"
Ding ding ding we have a winner! There's a second check valve on the bottom. The top one is a PRESSURE relief valve, and the bottom one is a VACUUM relief valve. Looks to me like the VACUUM relief valve was DOUBLE GASKETED and FULLY BLOCKING FLOW.
I pulled BOTH of those gaskets off and put it back together. Then I pulled the return line back off the filter and I'm getting way more oily vapor than I'd like, but at least I know it's FLOWING now.
I'm going to run to work tomorrow on the assumption that the blockage caused the crankcase vapors to push oil out any seal it could. I did top the oil back off so we'll see how it goes from here.
I'm probably due for an oil change anyway, and I'm sure that wouldn't help with any of this either.
chillman88
Central NY
Well it's still leaking oil pretty decent. It's certainly NOTHING like it was, but it's still leaving a decent oil spot when I stop. Pretty sure I'm going to order a turbo seal kit from @typ4 and replace the return line o-rings while everything is off. That'll give me a good opportunity to degrease everything up top.
No pictures yet but I got the brake controller installed. Seems to work ok but I had to turn the boost way up. Might just need to adjust the trailer brakes though, haven't adjusted them since I left for Texas last summer :oops:
chillman88
Central NY
Well this has been driving me nuts for a while now. Every once in a while if you turn just right or hit a bump this thing made a loud metallic bang. Crawled under the a couple months ago and found the problem. Finally got around to fixing it.
Pulled the bedliner out to assess the situation.
That's not great, but not terrible either.
Yup that'll do it!
Rotted right out on the underside too. The underside shots were taken after I cut the old bolt out.
I was also missing a nut further back on another bed bolt. No clue how I managed to have the right size on hand. I think they're M13 bolts.
I don't plan on doing anything intensive right now as far as body work goes, so I just cleaned it up and slathered some aerosol bedliner on it to cover up and slow the rust a tad.
Sloppy, but it'll do.
chillman88
Central NY
So what to do about the unexpected hole in the top of the bed? Well a little scrap 1/4" plate, a grinder, and a drill, plus some crappy quick primer work and voila!
Hit it with some bedliner spray and ran a bolt through it. Sorted!
Now, what about the hole in the bottom?
Well... My employer drives me nuts sometimes, but it has it's advantages.
14ga laser cut with holes for plug welding it in ;Sweet
Made the flange just a smidge too wide, so it's not sitting perfect on the front, but it's fine for this truck! Everything is in and tightened down so hopefully no more banging hitting bumps!
I'll plug weld it and paint it sometime. Maybe when I finally get to work on the body mounts.
:Thumbs Up
chillman88
Central NY
Well I looked back at the rear sway bar bushings and wow they're shot.
Wait a minute... I have that kit I bought for the dually that was the wrong size but......
Perfect!
Waaaaaaaay better than the old ones :confused:
I'm sure the rest of them are shot too, but these were almost metal on metal, and I already had them so technically they were free!
chillman88
Central NY
I need to get out from under this thing. Please tell me that's not....
Oh I hope not...
Son of a.....
Gahhhh! Why can't people torque these things properly!??
I can't afford new shocks yet, but I'll at least have to replace the bolts and torque them down good.
They're factory Ford parts judging by the part numbers. I don't know if they're original or just dealer replacements. Definitely due for replacement though, and I'd bet the fronts are the same way :frustrate
EDIT: Fronts look fine which is awesome!
chillman88
Central NY
This is the bolt from the first two pictures, the driver's side. It's the worst. The bolt and wallowed out hole is the passenger side.
Somehow miraculously had two bolts the correct size and thread, but they're 8.8 not 9.8. I put them in for now so the holes don't get any worse.
Selahdoor
Index Wa
8 is enough.
But I'd do something about those wallered out holes.
Go to Lowes and get some of those huge thick washers made for concrete work, and weld them in place, er sumptin...
chillman88
Central NY
8 is enough.
The old ones were 9.8 is the only reason for saying that.
I hope to fix the holes but... Honestly I plan to do lots of stuff that never gets done LOL
I have to get it in the garage and weld in that support patch piece, maybe I'll get to it then.
Honestly I'll probably replace the M12 bolts with 1/2-13 when I get new shocks.
Selahdoor
Index Wa
I would.
9.8 is overkill for that. (Maybe they were counting on people not torquing them correctly in the future, and having what happened here?)
Grade 8, 1/2-13 bolts will work fine. With nylocks so whatever you torque it to, it won't rattle itself out.
pwillis
