Did I get a good deal?
Metalmacguyver
Plymouth MA
I got this
and this
and this
and this
and these
All for $500 bucks..........
Did I get a good deal?:rotflmao :dunno cookoo :D
Metalmacguyver
Plymouth MA
Yeah..... now I just have to decide what to do with it all.
My truck is currently on its last legs. I have noticed the coolant dissappearing and the clutch is starting to slip.
So. I have a motor thats about to die. A couple of 6.9s, a 7.3, a blown e4od, a good c6, a good zf5, a extended cab f250 dually, a factory turbo setup or a good chunk of one, and trouble making a choice.
What would you guys do with all this stuff?
Metalmacguyver
Plymouth MA
Uh Yes!!!!:thumbsup:
You by chance have an extra e4od?;Sweet
Yes..... but not if your looking for one in good running order. I do know where I can find one at the junkyard for 150 w/o the TC. It has not been there too long. the truck ran when it went in there but needed some serious help to get it started.
NCheek
Howdy
College Station, TX
I would get to tinkering with one of those spare engines if your current powerplant is drinking the green juice... Gaskets you can fix, cavitation you can't at least give yourself a little preparation.
h2odrx
Anti-O
Coastal Neckville, NC
I'm looking one for a core and or spare? cheaper the better!
94f450sd
somewhere,ma
also make sure you check the rear axle in that ambulance before you scrap it!! it will most likely have a dana 70HD in it.that axle is worth 900.00 alone.and will fit that dually if you move the spring perches.
