Dana 60 seals and u-joint replacement
MtnHaul
California
Quick question here. What seals will I need to have on hand when disassembling a D60 to access the axle u-joints? I've never done this repair and I don't have a parts runner so I really need to have everything before I start. Also gonna' replace lower bearing on the knuckles and grease the wheel bearings--anything else I should look at while I'm in there?
Edit: Should've mentioned the axle was a '87 or '88 kingpin out of a DRW
aggiediesel01
Houston, TX
Not a super easy question to answer because of the little changes through the years. But this resource has all the answers.
http://www.billavista.com/tech/Articles/Dana_60_Front_Axle_Bible/
u2slow
bilge rat
PNW
I did a ujoint last year and managed without buying any parts other than the ujoint. Spindle has to come off, but knuckle does not.
Get a hub/wheel seal at a minimum if you plan to fully clean and repack the wheel bearings.
Black dawg
sw mt
spindle kits will have what you need+wheel seals and spicer life series joints
WarNose
Bay Area, CA
There are axle seals at the pumpkin that can be changed. You have to pull the gear carrier ( I think that is what it's called) to access them. The hardest part is putting the carrier back in. I had to build a case spreader and it was still a very tight fit.
