dana 60 parts interchange
dave186
Idaho
So I found a king pin d60 in a u pull it yard that's in a 87-91 crew cab. It looks like its in decent shape but its under the truck still with no wheels on it and no locking hubs. What I'm wondering is if the hubs and rotors from my d50 will bolt on? I'm worried the wheel bearings are rusty and mine are all new. Also what about the ring and pinion? Its the right ratio but I won't know if its any good till I open it up.
forcefed
Newark, OH
like said above. All your dana 50 stuff will bolt right up to it. Even your spindles are interchangeable if the ones on the axle are no good. If you need new upper king pins I have some but without the nylon bushings. I bought the whole rebuild kit and I did not need the new kingpins. I just used the bushings.
dave186
Idaho
Yes its a high pinion 60. I also found a 4x4 dually that I might buy if I can get it the right price. Its got a ball joint 60 in it but that's fine by me.
Alleycat
