aiyana7.3
IDI Enthusiast
Hey everyone!
I have had an issue with the ignition lock cylinder for some time - the key broke off and I couldn't get it out. I tried all the tricks online of how to replace the lock cylinder but it wouldn't work, and I even took it to quite a few mechanics who couldn't get it, so I have been using a screwdriver to turn it. I also cannot find a new steering column for a diesel, tilt wheel, automatic, cruise control, etc. So what I want to do is add an overhead console that contains switches for on, glow plugs, start, and high idle. I would also like to have a generic on/off key switch mounted in dash so no one could just get in my truck and start it without a key.
This is a link to the type of switch I want to put in - they can laser etch any lit emblem into it: http://www.otrattw.net/CONTURA-V-ENGINE-START-LOWER-LED-INDEPENDENT-V1D1JWWB-PZCSE-500.html there is also a wiring diagram on the page.
my understanding so far is that there are a group of wires that lead to the master lock cylinder. when the key is turned certain wires power certain things depending on the position of the key. what I need help with is which wires go to which switches, where they go on the switches, when the switch is flipped will the wire be powered or simply grounded to complete the circuit, do I need to add any fuses or relays or are the wires already protected, can I daisy chain the powers and grounds for the switches, etc. Basically, what is the best way to wire this?
I don't know a lot about wiring or the master lock cylinder so I appreciate any help. Thanks in advance!
