Cross shaft
cbarm
Medicine Hat, AB
Is there anywhere to get a descent price on cross shaft bushings and also the pin at the top of the clutch pedal to push the rod into the clutch master?? I just came out of the stealership after almost passing out at the price...
Clutch pedal lever, bushing and cross shaft bushings - $83.51 Unfrigginbelievable...
The lil arm is only a FORD item and I think the bushings are too...IIRC..don't ask how I know:mad:
Now question to you...did you ask them to sharpen their pencil on that price?..sometimes asking nice gets a gooder deal LOL
cbarm
Medicine Hat, AB
No...I was not to thrilled when I got the price so I said hell with that...Im gonna go ebayin again...like every other day lol
Whatcha willing to pay...I got a couple used bushings...LOL and you can do a mod on that arm....remove pin and install a bolt and put a heim joint on the end...there is a tech article on it...and it makes the pushrod adjustable too... ;)
I'l see about the bushings tomorrow..PM your adress
cbarm
Medicine Hat, AB
Sending PM as soon as I type this...the 'lever' looks like a flat heavy bracket with the pin on it and that was the most expensive part - $47. What is in there now is a bolt with a nut in place of the pin...gonna have to take a closer look now that I know what the parts look like. Is it a big job to replace the cross shaft bushings? Is there anything that I can improvise with?
