Biggz
Okay guys so I swore and be damned that I would fix my 1991 and drive it again, but I found a 1993 4x4 auto with a ATS turbo kit on it. Now for the bad I test drove it around the block and the transmission shifted kinda hard, the salesman said it had a shift-kit, understandable if you saw the kind of condition the truck was in and how clean and maintained the engine was. So I ended up giving the lot a beat up ass 2002 toyota corolla and 500 cash. But when i went to drive it home the trans would start out in what feels like second gear and when i pinched it it will downshoft first for a moment then with 2 seconds go from second to third. It wont go into overdrive cause at lik 55 this thing is humming along at 2300 rpm. The whole time all this is happening the damn OD off light is blinging in my face. But cruise control still works fine. Now for the questions:
1. any ideas as to where to go from here
2. My 1991 is a 4x4 with a ZF 5 speed and 4.10 gears, will the transmission and t-case bolt up to my 1993 as long as i use the flywheel and all that stuff.
3. Will the driveshafts swap over from truck to truck
4. Are the electrical plugins the same trans. wise from truck to truck
5. Is there a way to retain the cruise control when swapping in the manual
