Crank no start
Glsawyer
Aberdeen,wa
Just got a 2006 f350. Crew cab 4x4. Auto. 6.0
247k. It cranks and won't start. Sat for about 6months do to no start. So far I've done
Oil. Filters. Fuel pump was replaced. Fresh fuel. New battery's. Starter.
It cranks good. Fuel pump pumps. While cranking it will hick up and puff a little bit. Not much. No oil in coolant. No coolant in oil. It tries but just won't start.
I plane on a new crank and can sensor. What else should I look at? Last owner said something about a pump was replaced costing them almost $1000
Scan it, see what the codes are telling you. Do you have a check engine light, or green wrench light? A 6.0 will tell you what it thinks is wrong. I wouldn't change any parts until you pull the codes. Throwing parts at a 6.0 can get expensive and not get you anywhere. Don't use a cheap scanner, most won't communicate with a PSD. On my wish list is an AutoEngineuity with the Ford upgrade pack. One of the $50 from Harbor Freight isn't what you need.
A $1000 pump sounds like a HPOP (High Pressure Oil Pump). Hopefully, it didn't come apart and send FOD into the engine and injectors.
First thing to do is see what its telling you, then go from there. On the PSD's scan first then fix. It will save you a lot of headaches.
Glsawyer
Aberdeen,wa
wrench light comes on if i crank it for a really long time. then goes off when i cycle the key
Willis Ponds
Lodge, SC
For some of the best troubleshooting tips you should check out Diesel Tech Ron on Youtube. There are multiple things that could cause a no start condition. One of which is the FICM voltage which I didn't see you mention. Ron goes through the steps on how to test it.
Glsawyer
Aberdeen,wa
I will be checking the ficm today. Also swapping all filters for motorcraft. I was watching his vids last night. Seems the aftermarket oil filters can also be a cause.
Glsawyer
Aberdeen,wa
Also checking that today. Plans for today are
All filters. New motorcraft. New belt. Ac pump replace. Ac lines replace. Pull and inspect ipr. Bubble test. Check codes. Charge battery's. Check gp's.
hoodshauler
PARKER, CO
FICM voltage needs to be checked for sure. That would be my first priority
Glsawyer
Aberdeen,wa
Owner replaced hpop. Ficm. Ipr. No op is shops thought.
Also failed bubble test. Code shows up on number 4
Glsawyer
Aberdeen,wa
Data reader says following
Icp voltage 0.239
Egr valve position 0.985v
Injection contraol pressure duty cycle 14.84%
Battery voltage 11.75
Ficm vehicle power 12.0v
Ficm logic power 11.5v
Ficm main power 48v
Cam and crank sensor position sync. In sync
Ficm signals for cam/crank sensors not in sync
Control module voltage 10.855
Glsawyer
Aberdeen,wa
So I cranked it for about 2 mins straight. It finally fired. Ran like 2 secs then died. Crannked again something. Then battery's died.
So I assume because it did fire off atleast for a sec then that mean I'm ok for oil pressure?
Glsawyer
Aberdeen,wa
That noise is threw the intake. Drove about a block. Mad it to 10mph and started blowing smoke out the intake.
Egr is bad. I've attached. All the codes also.
Glsawyer
Aberdeen,wa
ok guys. egr valve stuck open. i wanna do a delete kit. any warning? is that a smart idea?
Lance
