no fuel truck down
Stuka
Ga
1993 IDIT manual I started her up and i drover her then i parked her in my driveway went to start it the next morning no start no white smoke which it normally does alot of on start up put a bit of starting fluid and it sputtered to life then died im going with no fuel I feel like i can rule out injectors cause there is no way in hell all my injectors are going to eat **** at the same time so im thinkin IP which would suck or Lift pump need to know if there's anything I'm missing or if threes any other means of fuel system failure
DirtyWood
Earth
If you're at around 1/4 tank full it's possible the rubber "shower head" fuel pickup broke off inside the tank and you're suckin' air. Switch tanks and see if anything changes.
Stuka
Ga
Both tanks full
Id say that the fuel bled back to the tanks because the check valve in the fuel pump is stuck or wonky. If you got a friend, have them pull start you, it's a lot easier than just cranking.
