Could it be headgasket
Gebadia
Plains MT
Why does my 89 7.3 f250 upon cold start instantly builds pressure in radiator than sucks sucks it all in soon as u put cap on builds pressure more pressure than it should could it be headgasket
You are for sure getting compression into your cooling system. It could be a head gasket, but it may be a cracked head too. I'm not sure that you can tell without pulling the heads off.
Gebadia
Plains MT
Thank u that's wat everyone's been saying I guess I was hoping for different answer lol but thank you for your time I'll let u know when I pull it apart wat the verdict is
And don't forget cavitation.......
From what I've seen, that's not a very likely possibility and I didn't mention it for just that reason. The hole would have to form pretty close to the top of the cylinder in order for the piston to not cover it up. It seems like most of those holes liked to form around the middle of the cylinder (up and down wise). Could it happen? Sure, but I've seen one or two that had that and burned coolant. Otherwise, they ran fine and weren't getting compression in the cooling system.
I had to go for "worst case scenario", keep me balanced.
pwillis
