Stu Bailey
Hello my trusty diesel techs. I have come to a bump in trouble shooting my truck. I have an 86 F250 6.9 with 159,000 miles. I’ve never had any real problems I’d say, just minor little fixes here and there. Currently, I am having a coolant problem, or so I believe.
I drained and flushed all the coolant the other day and installed a new block heater and motorcraft e5tz-8575c Tstat along with the gasket. Ran a thin bead of rtv sealant for it as well. Filled her back up with about 4 gallons of coolant and then ran the truck for about 20 minutes with the radiator cap off. At this time, coolant was pushing up out the radiator and the stock temp gauge still read C. My aftermarket numerical temp gauge read about 160. Obviously one is invalid. And what’s going on with my coolant? I thought it is supposed to suck back into the block and lower the level from the radiator so I can fill the last galling or two and call it quits. Manual says 29 quarts is capacity with 5 in the reservoir. No leaks anywhere. Oh, and I’m blowing cold air out the cab vents with heat setting on max.
