No, not really. They all will run at different places on the gauges. They can/will also vary at different times on the same truck. They are designed to give the driver a false sense of security, but all they really mean is that the gauges and senders aren't unoperational. I've had some trucks where the gauges would read higher when the headlights are on. I've also has one that, at random times, only the temp and oil pressure gauges would read higher or lower. Always at the same time and in the same direction. That worried me at first until I realized that if the oil pressure was really as low as the gauge indicated, then the engine temperature would probably be higher (gas engine).
