Black dawg
what kind of numbers are you guys getting?
how many "puffs"
how many "puffs"
My rebuild has 530 lbs no matter how many times I have tested it. the 300 sounds like it getting down to the rebuild so watch this closely. Are you using a quality compression gauge. If you are not at least your getting a steady reading across the 8 cylinders. It could be much better than what the gauge is telling you... Or worse. Do you have a direct drive or a gear reduction starter... And was the batteries fully charged up. Generally speaking the faster the engine spins the higher the compression ratio will be..
