Cold timing advance
Josh Oldenburg
Baileyville IL
I'm running the motorcraft ZF9 I think whatever the 7.3 is supposed to run. I have however bypassed the controller because the controller wasn't working right. So no matter what I have to run 12 volts, right?
Sent from my Pixel 3 XL using Tapatalk
Run 12v directly to the plugs and don't hold the button longer than 10 seconds at a time. Hold the button the minimum amount of time it takes for the engine to start.
Scrench
Missouri
I hold mine for 3 seconds an it fires right up. I watched it before I screwed them in and counted to 3 and they lit up like a cherry
Scrench
Missouri
I came off the solonoid with my power to the GPS. Then from the small solonoid side to my push button. Actually thought about using the accessorie side of my universal key switch that is mounted loud and proud in the dash but I think I'm going to yank the column out and try to fix it. This thing has had someone under the dash that must have been selling the copper it's terrible
