89dieselbko
OK so i just replaced my MC/slave/clutch hydrolic line, and spent LITERALLY 4 hours trying to get it to come up to pressure. we bench bled the slave, used the *bleeder* tool thing (had my neighbor give me a hand) after all that we just barely have clutch involvement. cracking the bleeder appears to only let fluid out, no air.
flywheel clutch throwout and all that jazz is new, after i swapped the motor/trans it only took about 2 hours to get it bleed, but my old slave was leaking so i replaced the whole system.
i guess the point of this is... could i have a bad part? there are no leaks in the system, we both cant figure out why its not getting up to pressure. at this point the pressure plate is moving just fine, and the clutch pads themselves you can just start to feel trying to move, but has been that way for a good 50-100 pumps.
Also the pedal is sitting in about the middle of the pedals full movement. Not sure if that could be the cause of a bad mc/slave or if it just needs more bleeding? im stumped and the bko is sitting another week due to this issue. I would assume bleeding would let air out, but it seems to be purely fluid. You can *hear* what sounds like air in the system, but his bleeder and the bleeder valve arent getting any air out... im totally frustrated at this point!
sorry if this has been covered before, hit a few of the other clutch pressure threads and they dont really seem to be the same as my problems
