Matrix37495
The Amish Wolfman
What is the best (safest) way to clean gasket surfaces? Anything from thermostat housing to head gasket surfaces....
Be really careful useing acetone. It will get absorbed thru the skin and settles in the kidneys never to leave them... Not a good thing either. I like useing a single edge razor blade fastened to any of the tools for that. Then a kitchen scotchbrite pad and some aerkroil with it. That will chine any steel for sure. Then some brakeclean but no rag wipeing it off because your likely to leave rag fur on the edges of a new machined surface. If a rag leaves behind some fur then use a map or propane torch to burn off whats left. Thats about as clean as you can get something too... Am I just a little over board on this cleanlynees thing... Yes.. But I'm happy too...
I used brake clean and a putty knife to clean the waterpump.
It was stuck on pretty good so I soaked it in brake clean, then with the putty knife it almost came off in one piece.
I've seen some special gasket removing chemicals, just never tried them.
I may not have called it the right thing.Forgot about the putty knife. Those things are great for scraping old gaskets off
