SparkandFire
We're drinking beer
A friend of mine had done this on his Yeep. I guess its somewhat common for the low $$ Jeeper guys to do (as the high $$ Jeep guys drop the dollars on ARB air lockers and such)... Like mentioned, you can unlock whichever hub you want and it will drive like a standard open differential.
With the spider gears welded, both axle shafts turn at the exact same rate all the time, no matter what. If you unlock one hub, then it will behave more like a traditional open-front when 4wd is engaged, still lunges and bucks due to the ratio difference between front and rear when turning..
Only real problem with the Lincoln Locker (or Miller Locker, or whatever) is that the welds force those little spider gears to handle immense load, especially when running big tires. A traditional locker has either a big locking clutch, or something similar. Think about how much leverage is hanging on that little 1" diameter spider gear when the other end of the axle shaft has a 37" tire hanging on it. Then add all the weight and inertia of a big heavy diesel powered truck on the other side of that little 1" gear...
