champion glow plugs
Smokey73
Peeltown, tx
-cuss I would like to find the sob at champion, who decided that they should start making glowplugs, and kick him square in the balls:kick:, twice. Two months ago, and I know its mostly my fault for doing so :oops:, I put a set of champion plugs in Big Russ('90 F250). After drivin it a few times and a few good cold mornings, the glowplugs quit working. I checked them this morning, and they were all bad. Now, I figured something was amiss, and come to find out the gp controller took a dump, all the resin was melted, and that might be what took out the gps. At this point everything was going well, no hard feelings toward anyone, until I tried to pull them out. Three of the eight actually broke off in the head. I used a pair of vise grips and a heel bar to get the rest out. I thought that maby, just maby the tips were small enough to not cause any further problems, I was wrong. I've never heard an engine knock like that and keep all the rods inside. I spent all day pulling the head and picking pieces of glow plugs out of the pistons.:mad:
So very sorry to hear of this. Thats a costly lesson learned but sometimes thats what it takes. Now if everyone reading this can learn from you experiance maybe they wont make the same mistake. Do you know what caused the controller to melt?
Smokey73
Peeltown, tx
not sure what caused it, but I've had my suspicions about it for a while now. It just hasn't seemed to be working right. When I pulled it out yesterday, all the goop in it was melted and ran down the back of the engine. I went ahead and completely disconnected the controller and ran a switch for the relay.
VanBoy
WA
....I though I just read a identical thread and posted in it.....:eek:
Smokey73
Peeltown, tx
next time I have to change out gp's I'll try that, it might take a little longer, but not as long as pulling the head. Luckily, it was the left side and not the right.
btw sorry about the double thread, not sure what happened
