Zigg's statements are correct given the realativity of it all. I've been meaning to post a picture taken while looking down the air intake of the Moosestang. It's squeeky clean alluminum in there. The photo caption will read "why I run a road draft tube". I don't think the rear cylinders getting most of the oil has to do with forward motion. More likely, it is the fact that the engine doesn't sit level in the truck, and the CDR opening is in the rear of the intake. The wind going down in there forces the oil to the rear. Like Jim Crochie sings "You don't spit into the wind". I made a condensor for the Moose Truck out of a weed sprayer filter, available at any farm and home supply store. The amount of oil it collects is minimal, but so is the blow by. I should try one on the Moosestang, but just haven't gotten around to it. I rented a truck for work the other day... one of those **** ant little Izuzu cab overs with the 4 cylinder engine. I looked it over, and saw the RDT comming out of the valve cover, making a quick 180 degree turn and pointing down just below the oil pan. One reason I think we see so much more blow by then other diesels is the high compression we have at idle. Our engines are just going to naturally squeek more gasses past the rings then other engines with all that cylinder presure that other motors don't see until they get a significant amount of boost built.
