CDD 38 Gallon/Single Tank Conversion Kits
jwsfarrier
Molalla,OR
Hey Wes, this is something I would like to do on both of my trucks. It's great you have gone through the trouble of sourcing the right parts . Love the sump set up. My question is since the tank sets below the frame rails will it clear the mounts for a receiver hitch. Taking a quick look at mine it looks a bit tight but I just eyeballed it.
Thewespaul
Bulverde, Texas
This tank doesn’t come out and wider or further rearward than the stock tank, just continues down about 7-8” deeper than the stock rear tanks, I’ve installed several with trailer hitched and although I can’t speak for every trailer hitch design they did fit. I did find that it’s a lot easier to install them from the top (removing the bed) if there’s a trailer hitch in the way, since you can install the bottom straps and just set it in, tighten the top straps and then the bottom.
