larson
Can the seals on the 7.3 oil cooler be swaped out properly in a day? Turning wrenches is nothing new to me but this is the first diesel I have ever owned this is why i ask. I read the tech article and it seems pretty straightforward but I want to hear from you guys experience with this and please tell me anything I need to do that might not have been mentioned in the tech article that makes it easier or helps with correct install.
Also if there are no oil leaks on the top side and there is only oil on the driver side of the motor then I'm assuming its the oil cooler from what I have read here on this forum. Its a slow leak and rarely gets on the ground just all over every thing bottom side. Valve covers seem leak free so I have come to the conclusion that its either the oil cooler or PS pump. I'm kind of in the dark cause the **** is every where and I can't pin point it.
