>>> FUEL HEATER DELETE <<<
Immediately above the fuel-filter is a fuel-heater; absolutely useless and un-necessary; notorious for leaking fuel.
When you spin off a fuel-filter, the heater will slightly turn on it's stud; when you spin on the new filter, the heater will turn the opposite direction.
You will fire up the truck to test for leaks and you will see fuel drip --- drip --- drip off the bottom of the filter.
Naturally, you will assume that something is amiss with your filter mounting method.
You will screw off the new filter, inspect that there was indeed an O-ring seal on it, check the mounting base to assure there was no errant extra O-ring on there, lube the new O-ring and re-install the filter.
The drip just got worse.
You will grab the filter-wrench and give it a healthy squeeze; still DRIP -- DRIP -- DRIP.
Squeeze some more; still dripping.
Finally, you will discover that there is indeed a CUMMINs only O-ring seal on top of that heater that can only be had from a Cummins store (or some concern that has gotten them from there).
You will spend money and wait for UPS to bring the new seal; you should have gotten two dozen; because, every time you mess with the fuel-filter, that seal is gonna get trashed again.
Oh yeah; oh yeah; there are some that are afixing to jump in here and claim
"it has never happened to me"
; never mind, there day is coming and hopefully they remember reading this.
There IS a much better way.
Remove the fuel-filter.
Using whatever proper tool it takes, remove/un-screw the filter/heater mounting stud.
Un-plug the heater wires and zip-tie that plug back out of the way.
Throw the heater and all of them odd-ball O-ring seals way out in the pond; good riddance.
Avail yourself of a standard issue Cummins fuel-filter mounting stud that deletes the heater.
The filter will now seat against the upper surface where it was originally intended to do so.
Never again will you be on the side of the road replacing a filter and un-able to get it to quit leaking.
