c6 with e4od converter
idibeast
Granbury,TX
Hey guys, just a quick question, do any of you know if an e4od torque converter will work with the c6 transmission. I might be replacing the e4od in my 1996 7.3 and i know the bellhousings right, but dont have a clue what to do about the torque converter, thanks again.
sassyrel
iowa
doesnt work................totally diff trans...................
idibeast
Granbury,TX
Well that sucks, but another question, do any of yall know how i might get this to work. I would really like a c6 behind my 7.3 (much cheaper to build) or is there no possible way?
trackspeeder
Stone crusher.
North Branford. CT
It can be done. The big issue is the vaccume control crap. I
You can go with a manual valve body to solve the vaccume issue.
Last you will need to redrill the flex plate. There is no four hole flex plate available for a PSD.
idibeast
Granbury,TX
I planned on going full manual with a floor shifter, but i was wondering about the flex plate, how would i drill it and wouldnt that throw it off balance, what if i got one from an idi, cut out the bolt holes in the center and welded mine in place.
idibeast
Granbury,TX
Thank you all very much, i think im going to do the swap and drill the flexplate. Thanks for the info.
