C6 Speedo Gear ?
Hydro-idi
Lodi, California
Hey fellas,
Just installed 3.08's on my rig today and the speedometer is off by approx 10 mph @ 50 mph. So when speedo says I'm going 50, im actually going about 60 mph. My transmission currently has the 17 tooth green speedo gear. Im assuming I will need a gear with fewer teeth on it. Doing some research, it looks like I might be able to get a 16 tooth but no less. Is this true? And where can I acquire this gear?? Any help would be appreciated. Thanks!
DaveBen
Ukiah, Ca
Look at one of the many tranny shops that are NOT associated with large companies, like Midas. Small home town automatic mechanic.
Dave
SDEconVan
San Diego CA USA Earth
Hi Hydro-idi,
You have a few options to get the gears right for the speedometer.
Check out the build thread for my transmission and transfer case. The transfer case housed
the speedo gears and I show how I went to adjust the ratio. Now, using GPS, the speedometer
is right on the money!
http://www.oilburners.net/forums/showthread.php?69057-1998-E4OD-on-the-outside-wait-a-minute!/page10
Scroll down to #145 (I show the calculation there)
The Mustang guys seem up on this stuff. Places like Scott Drake and CJ Pony Parts will have gears, as will the
big stores like Summit (not affiliated with any of these)
http://www.summitracing.com/search/part-type/speedometer-gears/transmission-make/ford
Hope this helps.
Best regards,
George
Hydro-idi
Lodi, California
Went to a mustang shop this morning and picked up a 16 tooth gear. That's as low as it goes. Ran it down the road and it's about 4 mph off going 55 which is better than it was. Don't want to take transmission apart to replace the other gear so I'm going to run it.
Seven4eight
