You have two problems then, one it smokes a lot, this could be a leaking injector/s bad timing (how many miles on the fuel system?) and burns oil, could be rings, valve seals, etc. The most simple is to look inside the intake and see if there is any oil coating the walls then You know the cdr isn't working.
Does this truck have a turbo? any more info like year, engine, etc?
