BTS tranny question
6_Myles
I be architect'n
Asheville, NC
I'm kind of looking toward the future here, but will a 7.3l which has been stoutly built (Hypermax turbo, 3" exhaust, stage 1 IP & injectors, and moderate boost...nothing too crazy) every generate enough power to warrant the expense of a BTS tranny? I guess the better question is will a properly built & updated e40d from a local tranny shop, for less money, withstand the abuse good enough? :confused: I know it all depends on the mechanic turning the wrenches, but for this discussion assume that it will be built correctly.
Please let me know if I'm wrong, but it just seems to me that the BTS is overkill for the idi 7.3's that will maybe make 600 ft-lb's totally bombed out, and more like 500 ft-lb's for what I'm looking at doing. But it does make sense in the newer PS strokes that are making rediculous amounts of power.
Now I do like the idea, of never, ever, ever having to worry about the tranny taking a dive with a BTS, but d@mn that thing is almost twice as expensive as a rebuild locally. What do the people have to say? :hail
Mikes91
Melbourne, FL
Well, I would say this has LITTLE to do with power and EVERYTHING to do with reliability towing heavy loads.
I have a BTS unit in my truck, and there's nothing that COMPARES to having the confidence that I'll make it to my destination without the transmission giving me trouble. I love this transmission.
I *am* having a smoke issue in Reverse and 1st, described in another post, but don't know if it is transmission related. Given Brian's customer service to others, I expect he'd probably drop the trans and check it out for free. He's gone even further for other folks on this board, updating changes components or slightly worn components on transmissions he's built for them at no charge when they've had the slightest issue. Brian sounds like a good guy who'll go the extra mile to take care of his customer.
Anyway... if you plan on doing any towing of significance and your current trans is shot, I'd suggest a BTS.
The Ford/Jasper/whoever rebuilds would probably last for awhile. Not sure what their warranties are. IIRC, I have a 2 year, unlimited mileage, unlimited power warranty with the BTS.
The previous rebuild on my truck lasted 30,000 miles. The first pull of 10,000 pounds fried it. I've towed moderate weight across the country, up and down the Continental Divide, with the BTS unit. Zero issues.
Again, I don't see this as a power/durability issue for our IDI trucks as much as a towing/durability issue.
Mike
dsblack
Washington State
I do not know what BTS wants for a trans, but I bought a Ford, installed for 3K.
With a 3yr 36000 warranty. It is now on it's 3rd one under warranty.
Will I spend the extra on a BTS trans. next time. ? Well, lets get the engine fixed then If I keep the truck, I would spend the extra in a second! -Deadhorse
Mikes91
Melbourne, FL
Another thought... Perhaps the biggest consideration is what kind of condition the rest of the truck is in, and if you plan on keeping the truck...
