I will let you do the math...but I will explain principle
2 mc
1.25
1.3125
Pi R Sq = Surface area
Surface area x 1000 lbs force from booster....1000 is an example number = psi
Thus the larger MC vs the smaller MC =
Larger has less psi however greater volume to fill wheel cylinders and calipers
Smaller has higher psi however lesser volume to fill wheel cylinders and calipers
It is very basic and easy to prove....
Just sayin
Personally I run the Hydroboost MC
JM7.3CW
thank you for your explicit proficient analogy of why i should run the hydro MC.
please forgive my ignorance for not knowing which would work with which, also handing information on a half polished silver platter.
i had not a clue if there was a difference inbetween the two.
due to my lack of knowledge and obviously what should be common sense,
i shall now repent and move forward in life.
lets all bow to thee Al Mighty Riot warrior
