Waystro
No Class
Yep those washer look like the ones for the Brake hose.You must be registered for see images attach
I want verify that the copper washers are for the connection to the brake hose on between the caliper and brake hose(bottom) and between bolt and brake hose top. Also see the piston in the pic. That's what happens when drop it? I'm assuming I need to replace it but it's a shot in the dark to see if any of you that's to badly damaged. Lastly any one have a picture of the z-thingy (best way I can describe it) spring fits on the caliper. Both of my old ones where not there. Just want to make sure I'm putting it on right thank you.
Did you buy New ones?
