I understand we go to the farthest point from the master cylinder and work back from there but. When do I do the anti lock cylinder under the drivers seat area. Before or after doing the rear cylinders. Thanks all.
most people do it wrong. they pump and pump then bleed. spend all day bleeding and gallons of fluid lol
Now I've heard with out masters, we should release the bleeder before squeezing the piston back in because in can do damage to the piston cups in the master. Is that a possibility?
I know for abs cars you can foul the system doing that.
Yes, someone in the know told me that also about the newer cars and trucks. Pushing the piston back pushes all that old rusty fluid back up in the complicated abs valve system and can cause it to fail. After I was told that, I started to also do it on these older trucks. It's doesn't hurt the master, but our systems can also do without all that rust being pushed back up in the system, and also if you keep the master topped off, it will overflow and make a mess unless you release the bleeder and let the excess fluid come out there. By the time you do that, and then bleed them a little bit from the master, you should have mostly new fluid in the system, getting rid of that old stuff.
