gonecrazyi
I picked up a 92 dodge d250 a few weeks ago and thought Id share it.
It was converted to 4 wheel drive with stock dodge mounts. The springs are two 4 inch lift springs stacked.
The axle is I believe a dana 44hd with closed knuckles and kingpins with drum brakes lol.
The transmission acts like a 4 speed but I believe its a 5 speed missing 5th gear and the transfer case is out of a newer drivers side drop dodge truck.
Needless to say it is a bit of a basket case. But it runs amazingly well and fires up right when you hit the key. It also has an intercooler and all the pieces I would need to put it into my ford if I plan to go that route. As it is I like the way it drives and feels, but It needs a 4wd crossmember and a different axle and it should be ready to go.
